Originally Posted by BRAN
Well done!
Your trimming turned out pretty perfect. Indeed the driver side and the right side need slightly different trimming.
I wonder, if I will get the washer jets to work properly with the covers.
Thanks Bran! The washer jets protrude from the lens ~1/2” even when retracted so you would need to cut the covers precisely to fit. The washers extend ~2” when in use. The problem is that the washer nozzle assembly is not very cosmetically appealing (at least to me). The next generation extension washers used the flush ‘button’ covers, but they might be too large in diameter. One of the later year models have the small nozzles that permanently mount ‘out’ but I’m not sure which year models it is.
Rgds, Fred
