Old 10-18-2006, 09:03 AM   #10
Sammy
If you are in a pinch, you can get away with mismatched tires (never do mismatched on the same axle, NEVER!) but like was mentioned you will most likely see some funky handling changes and in some cases it could be unsafe. Keep in mind that not only is the tire going to have different handling characteristics, but your fronts will have some aging issues. If it were me and I wasn't going to buy 4 tires I would replace the rears with identical or comparable Pirellis.
Sammy is offline   Reply With Quote
