Old 04-15-2020, 11:13 AM   #2
pilut2
pilut2's Avatar
Originally Posted by Tailwind View Post
Guys
My Cousin has a '03 S, and the coolant tank is just above the low coolant warning level.
He has yellow coolant and wants to replenish the overflow tank and not have to do a complete flush. He is aware of the danger of mixing coolants. I had green in my '99 when the tank split and after research used Peak Pink premixed to top up.
I see Dex-Cool is recommended for his car, as is Peak Pink.
Please give me your opinions.
TIA
I would top it up with distilled water and keep an eye on the level. If it stays up then the couple of cups of distilled water will have a negligible impact on the mix ratio- if it drops then you need to figure out why. But, since the coolant is yellow it is likely original- a flush and fill might be prudent.
1999 Boxster, Ocean Blue Metallic-grey top.
LN IMS dual row-, Ben's short shift kit
pilut2 is offline   Reply With Quote
