Old 04-14-2020, 02:13 PM   #1
paulofto
2003 S, Arctic Silver, M6
paulofto's Avatar
Originally Posted by bcrdukes View Post
Hi Folks,
So naturally, I tried to adjust the head light vertical aim as per the owner's manual, only to realize the 5mm plastic hex nut on the passenger side headlight assembly is stripped. The driver side is okay and can be adjusted no problems.
Are you talking about the 'nut' that releases the headlight from the fender? If so are you using the supplied 5mm wrench from the tool kit? If so try a 5mm socket instead. It may be the tool not the nut.
If this 'nut' is what you are referring to it is actually a bowed arm that is available separately. Here is a page from the PET with part number. If this isn't what you are talking about then never mind.
