Old 04-14-2020, 01:40 PM   #6
Gilles
Originally Posted by Racer Boy View Post
It leaking from the bellows (from the rack seals). The area where the fluid hoses go into the rack is dry, so I'm pretty certain the rack seals are blown.
I'll just go ahead and try the rack first, and hope that the pump is fine.
Racer, before you remove the rack remember that some of the bolts that attach the subframe to the body are 'torque to yield' bolts that you have to replace, and the torque they require will give you a workout.. :-)
