Originally Posted by gabedrummin
So a little history 2000 Boxster S brakes are about three years replaced rotors and pads .I do a brake flush every year.
Driving home from work a couple of weeks ago the rear brakes develop some issue . I'm on the free way doing 80 ish within a few miles I pull off because I feel the cars brakes dragging . Both rotors are blue they got so hot the brakes were locked up. I get the car home and try to bleed some fluid off .
Just going by the info you posted above in red. Traction control is not necessary for ABS to control wheel lock up. The 2000 has 3 channel ABS, so yes only one brake line to rear.
