Old 04-10-2020, 12:38 PM   #10
Oldcarguy
Oldcarguy's Avatar
Now Available: Porsche 986/996 MK1 Headlight Conversion Covers
Did the final dry fit today. Plan to start painting tomorrow. Had to make the same small trimming mod on each side. It can be seen in the pics. I had no problem to trim and re-contour the edge. Also, I do not have the problem regarding the exposed headlight edge as shown in some posts. YMMV, however due to fender/headlight fitment, how you want the cover positioned, thickness of your tape or adhesive, thickness and fit of headlight film, etc, etc.
To properly test fit I had to apply pressure in the center of the cover to press it to the headlight surface while ensuring that the raised edges around the perimeter were properly positioned. The cover spread toward the edges somewhat when under pressure.
Rgds, Fred
