Old 04-10-2020, 05:03 AM   #1
986guy1
Coolant fill & Fan Issue
Hey all, I’m new to the forum but happy to be apart of it. I recently did water pump & thermostat replacement on my 99. I went through the bleed procedure a bunch of times with the rear in the air. Now I’m noticing with my durametric that my temps are getting pretty hot but no sign of the fans kicking in at temp. My temp has gotten up to 96 degrees C. I’ve tested fans by running Ac as well as test with durametric, just replaced my coolant cap with the updated 04 as mine was 00 but still nothing. Btw also checked relays and two fuses, just scratching my head at this point. Hope someone can help me out. Thanks
986guy1 is offline   Reply With Quote
