Old 04-09-2020, 06:34 PM   #11
JBauer
JBauer's Avatar
Originally Posted by Racer Boy View Post
On my old Miata, I had a similar problem, and using Gorilla Glue worked. The Miata top is vinyl, not canvas, but the inside of our canvas tops are rubber, so I would think the Gorilla Glue would work.
The 3m tape works perfectly if this is done correctly. I just did this about 6 months ago. Don't use glue. If you screw up there's no going back. If you make a mistake with the tape, like I did, just clean it all off and start over. Its not that hard. There's a reason the factory used tape.
