Old 04-09-2020, 01:34 PM   #1
1498asr
Convertible top transmission
Hello. I'm in the process of replacing the cables for the convertible top transmissions on my 2000 Boxster. The driver's side transmission has a microswitch that I'm guessing turns to the top motor off when the top reaches the fully open or fully closed positions . When I dissasembled the driver's side trans, I failed to take note of the position of the cam plate that triggers the limit switch. How do I install this plate in the correct position during reassembly so the motor operates correctly? Thank you.
1498asr is offline   Reply With Quote
