It means that the original 2004 engine was replaced with a 2004 factory replacement engine. It does not mean that the original engine failed because of the IMS bearing.
But since you mentioned that "there was a line there saying :NV Wty Intermediate Shaft", then it may be safe to assume that the IMS bearing was the cause of the failure.
The replacement engine has the same IMS bearing as the original - single row.
TO
