Old 04-04-2020, 10:34 AM   #1
Camscott98
Porsche Boxster 986 2.7 2000YR hunting / rough idle
Hello, this is my first post in the forum, I am currently at trying to solve the following issue with my Boxster:
From cold: the revs will sit just over 1000 (1100-1250) then after about a minute will drop below to about 750/800 which is normal I think.
At the 750/800 stage the car starts to hunt and run rough at idle approx 500 RPM variance, which feels and sounds like a light misfire. Even when the car is fully warmed up out on a drive sitting at idle this will still occur. Applying the throttle back to the 1100 range will stop the symptoms. No Check engine light or any codes.
so far to try rectify the issue I have:
fitted new spark plugs
cleaned the throttle body (which was dirty)
cleaned the MAF (looked brand new before cleaning) I've unplugged the MAF sensor while running and it made no odds, still rough.
Changed the AOS (Air Oil Separator)
Checked for vacuum leaks (can't find any)
Other than the symptoms at idle the car runs as it should the rest of the drive. I know similar threads have been posted before but I have read as many of those as I can posting myself was a last resort! Any help would be greatly appreciated thanks.
Camscott98 is offline   Reply With Quote
