Old 04-04-2020, 07:21 AM   #1
outsidetheboxster
tach connections
I have a question about doing just the opposite.
My engine swap is using a stand alone ECU that has a 5V tach driver output. As I'm not using the factory ECU to make the engine run, can I back feed the 5 volt signal into the same OBD wire to make the tach in the dash work?
I'm aware of the Tach Adapt product but I still need to find out what wire or wires feed the tach itself. 01 Boxster S 6 speed. I have the Bentley manual and wiring diagram but my eyesight is just not that good anymore.....
Thanks for any thoughts!
outsidetheboxster is offline   Reply With Quote
