Old 04-03-2020, 12:50 AM   #27
itsnotanova
I forget what style bolt head it's called, but if you see those type of bolts used throughout the motor. Then it's probably a replacement motor. it will also be free from any under body corrosion coating on the bottom. Every replacement motor I've seen was a lot cleaner than the transmission it was attached to.
Woody
