Old 03-30-2020, 02:19 PM   #1
Penland
Well if you want to drive it, then my recommendation to you would be to buy an OEM or Genuine Porsche tank. Ask Robdelorenzo on here. The seam on the aftermarket tanks are known to leak where the manifold to hose connections are. This can allow fluid to seep into the overflow line when the tank pressures up with the cap on.
I was changing the oil today and ran it a little, witnessed it leaking thru the manifold connections, new tank will be here Wednesday with new level sensor. Getting excited to be able to drive it again, thanks again!
Penland is offline   Reply With Quote
