Old 03-30-2020, 11:23 AM   #11
maytag
Who's askin'?
maytag's Avatar
Originally Posted by dav9515 View Post
with that many miles and age of the boxster while you're doing plugs you may want to consider replacing the tubes/o rings at the same time. On mine with 51k miles 2 of the 6 tubes had a slight leak so i replaced them all with the plugs. Easy job if you make the DIY "tool" (washers on a bolt) and they're cheap so may as well if you are going through the trouble.
unless you know they've been done before or aren't a "while you're in there" kind of guy. oh and for oil i just use 0W-40 Mobile 1 synthetic from Wal Mart, honestly works just fine on my little 2.5 and you can get it on sale for $20/5 qt.
Tubes and o-rings are not replaceable items on his '04, the same way they are on your earlier box.
