Old 03-30-2020, 09:28 AM   #1
truegearhead
truegearhead's Avatar
Help with Control Arm Modification
I'm widening my car by 4"s by extending all of the suspension arms. I was hoping to get your opinion on my control arm solution, its not as clean as I was hoping it would be. I've posted pictures below to show you what I've done to add 2"s of length per arm. Do you think this is strong enough?
Here is the original Elephant Racing design
Here is the new design, with a 1' sleeve and threaded rod
This is the new design assembled
SPL makes a similar control arm, they extend the arm using this shiney piece, its the same dimensions as the sleave I'm using to extend the arm which is a good sign (my design also uses a threaded rod which should increase the strength
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
