Old 03-29-2020, 06:14 PM   #6
NewArt
Artist, 986S tinkerer
NewArt's Avatar
A vacuum leak is a likely suspect. Try inspecting vacuum lines and maybe spraying some starter fluid around connections in the intake system with the motor running. If you hear an increase in rpm, you’ve found your leak. Try the easy stuff before throwing parts at it!
