Old 03-25-2020, 09:53 PM   #110
Homeoboxter
I inserted pistons 1-2-3 into the cylinders. It`s quite straightforward, just like on a conventional in-line engine.
Conrod bolts are now tightened down to 20Nm followed by a 90 degree turn as per direction from the 986 manual. Interestingly, the 987 manual`s direction differs, in spite of the very same bolts. It suggests that they should be torqued down to 20Nm plus 110 degrees, which then should be completely undone and retorqued to 20Nm and 110. Weird.. Since I still could do this easily, I`m thinking of retorquing the bolts based on the 987 directions. Not that it makes a big difference, but probably the engineers made this upgrade for a reason.
