Old 03-25-2020, 08:41 AM   #13
sfiorellino
The 5mm socket isn't the problem.
The 5mm socket isn't the problem. The bar that you turn inside the headlight assembly is stripped. Therefore I may need to replace the plastic headlight mounting plate that the headlight slides into. The headlight clamp is attached to the mounting plate which is what is stripped.
sfiorellino is offline   Reply With Quote
