Old 03-24-2020, 03:00 PM   #5555
Brian in Tucson
Originally Posted by Dubaday View Post
Yesterday, I removed the stock throttle body and plenum, along with an EVOM air intake, and replaced
it with a 997 IPD throttle body and plenum, and a custom carbon fiber ram air intake.
(setup was made from a fellow forum member)
during this process, I ended up breaking a "vent line / oil separator "
( part number 996-107-146-00)
I did not put tape on it... new one coming in tomorrow ($55 from dealership)
It was tough, but hands down the best upgrade I've done so far!
Images snipped! I broke the little vacuum fitting off mine (second one I've broken, btw.) Using a proper bit of brass tubing, I slipped it in, jammed it together and glued it all with Rhino glue and baking soda. Better than new! If I were you, I'd try to mend the old one as practice. Rhino glue is fancy superglue, btw. Used it to glue the window back in on my New Beetle convertible.
2001 Boxster
2007 Toyota Highlander
