03-23-2020, 01:39 PM
#14
Originally Posted by itsnotanova
That's the only rattle can I would recommend on a vehicle you care about. Claer coat paints you buy from your local store don't have a hardner in them and will get dull with sun exposure. Any clear you spray on headlights needs to be put on with very very light coats at first. You also need the coats to dry before laying on another coat. Putting a clear coat on headlights is not a rush job.
Originally Posted by Qingdao
Prep the lenses with 1000 grit before you spray the clear on. Don't spray a polished surface.
This is good info!!
Thanks guys!!
