Old 10-17-2006, 04:31 PM   #10
pecivil
no, 0-40 is not for cold climates. I would never use 15-50. It is much too thick, no matter where you are, or how hot is it outside.
read the articles in the link I gave below. Again, it is long, but if you can follow it, you will understand why 0-40 or even 0-30 is the better oil to use.
15-50 is needlessly increasing the amount of time that it takes the oil to reach operating temp at startup. This results in an increased time to achieve proper lubrication, and an increased time of extreme engine wear. All oils achieve the proper viscosity at operating temps.
The real variable is how long it takes the oil to get to proper temperature (i.e. to thin out) AT STARTUP.
the thicker the oil, the much, much longer it takes.
Anyway, on my boxster, there is a sticker on the trunk lid near the oil filler neck that clearly states "Use Mobil 1 0-40 ONLY"
Arctic Silver 2000 Boxster 3.4l w/Sport Design Package
Supersprint Boxster S Headers/Cats/Muffler
AASCO Lt. Wt FLywheel
Evo Intake
Partial Carbon Interior
Black Leather Sport seats
M030 Sway Bars
Litronics w/ Clear Corners
Boxster S brakes
B&M Short Shifter
PnP rear Speakers + Amp
pecivil is offline   Reply With Quote
