Old 03-22-2020, 09:35 PM   #5543
Steelepuls
Replaced transmission mounts
Put the boxster on the quick jack and changed out the transmission mounts. OMG, the vibration at 3K rpm is gone and it’s so quiet now. Tip for the next person to do this, you don’t have to take the bracket off on the right passenger side, just unbolt the two 13mm bolts and the 19mm bolt to the bracket and lift the mount off. Took less than hour. Replacing the left drivers side on the other hand took 2 1/2 hours. i took the bracket off with the mount. I think I could have just taken the drivers side off by removing the 2 13mm bolts and the 19mm bolt like I did to the passenger side.
Steelepuls is offline   Reply With Quote
