			My seat experience: I’m a bout 5’10”, but a very high waist. When I shopped around for seats I went to my local race shop and sat in all the seats I could. Arrived at sparco rev 2s. What I didn’t realize at the time was that the rev 2 is a super tall seat, but I got a pretty nice deal from rallymerchandise.eu.
 Got second hand Brey Krause brackets and tried to mount. The width of the seat put it right against the center console. The height with sliders had it protruding above the roll bar. Brey Krause sells brackets with sub strap to replace the stock sliders... I ended up having to use them to hard mount. The adjustment range with these brackets is too far between increments... could never get the exact right distance from the pedals, but found a spot that is almost perfect.
 Got a schroth profi 2x2 harness of ebay a few months later and rev 2 head and neck restraint. People don’t tell you when you get a seat for track duty, but it’s kind of a slippery slope. You get the seat. Feel awesome. Figure it’s easy to throw in a harness. Then realize to use the harness on track, you should use head and neck restraint.
 If you keep track of how much this probably cost... and consider I did both seats, I’m somewhere near 2k all in. That said... absolutely love this setup. Track seats are a must. Harness helps a lot too. Rev 2s are too damn tall for me, but width wise, my 33 in waist is actually also too small... but it still grips so good and is pretty comfortable when not on track. I clip and Unclip in the harness when I get to track events, just leaving in the top straps behind my seat when I’m not at the track. Love the setup. Would recommend.
 As others mentioned, it is not easy getting in and out of the car, especially with stock steering wheel, but you learn the technique. I still use my 3 pt when I’m not at the track. It’s weird though because I strap through the seat on the outboard side, over the seat on the inboard side. Velcro to keep the buckle in the right spot. Still requires a special technique to buckle properly. Anyway, hoping my experience helps someone.
