					Originally Posted by  jaykay
				Robert,
Perhaps slightly better performance and the proper match for the 987 MAF diameter; folks here are actively using it.  Full disclosure:  I have just changed from a third party tune to the stock 986S and planned to go to the 996 ROW.  I am not sure about the anniversary tune and don't know anyone using it.  I believe the anniversary is geared to the 68mm TB where as the 996 is geared to the 74mm.
You will: be able to start the car without depressing the clutch, reducing engine wear;
not have to worry about post cat o2 sensors/codes; loose the ability to monitor one cam shaft for deviation from ideal.
If it's no longer monitoring the post-cat O2 sensors, does that interfere with the IM testing?  In my state (Utah) it's a plug- in test, not a sniff up the exhaust pipe.
