Old 03-21-2020, 08:54 AM   #11
1thenaton1
you can't increase the diameter of the maf housing without adjusting fueling tables. MAF calculates the volume of air ingested using the velocity of the air past the sensor, which of course is a function of the size of the tube it's flowing through. The codes you are getting are generated in regular driving where the O2 sensors read lean/rich. At wide open throttle where the ECU is running on set tables (and not off of O2 sensor feedback), you will be running lean (increased airflow not accounted for because of incorrect maf housing size). Lean is mean, until it's not. Without monitoring this with a wideband O2 and updating to a custom tune you are asking for trouble, especially on track. What is you crazy
1thenaton1 is offline   Reply With Quote
