Old 03-16-2020, 06:30 AM   #25
NewArt
Artist, 986S tinkerer
NewArt's Avatar
Yes, this can be a problem for taller drivers (I am pretty average in height at 5'10"). The easy first step is to modify the mounting holes in the BK mount to lower the seat. That can probably buy an inch or so.
Of course, there is only so much adjustment that can be gained from off the shelf components, so if you're as tall as a sasquatch, then you might need to delete the slider entirely or create a custom mounting solution.
And, of course, there’s always the Brey-Krause roll bar extension which adds a couple of inches of clearance. The top, hard or soft, closes over it with no problem.
