Old 03-13-2020, 06:03 PM   #1
elgyqc
elgyqc's Avatar
Originally Posted by alynch View Post
Noticed another noise recently when exiting the car. Rotational noise. In neutral with clutch pedal out: noise. In neutral with clutch pedal in: no noise. I suspect a dry throwout bearing. Car shifts without issue and plenty of remaining travel in the clutch.
I believe I know the answer but I have to ask. Any way to lubricate the throwout bearing without removing the transmission? Boxster S with 69,700 miles on original clutch.
The throwout bearing isn't engaged with the clutch out. Your noise is probable the transmission input shaft turning, may be normal or could be a noisy bearing.
Grant
