Old 03-05-2020, 06:11 PM   #1
Vza
Litronic Upgrade
Well I upgraded my 99 Boxster w/ Litronics and its not working. This is the upgrade with Xenon lights and the control module which allows the low beams to rotate up a few degrees when turning on the high beams. I get the little dance when I have the light switch turned on before I start the car. The beams cycle up down then up again. This is the only time they move. Nothing happens when high beams are on. I checked the wiring pinouts, continuity, wiring (only 3 wires white,ground and power to wash nozzle. ) I also checked voltage. 13.7 V from wire tapped to washer nozzle when engine on, 13.7V from white wire when high beams are switched on. Everything seems to be wired correctly, the motors in the lights work and I have correct voltages. The only thing I can think of is a bad module(I actually tried 2 and got the same results) so they both would be bad or a bad light switch (but the high beams aren't activated from that switch) any thoughts on this? Thanks Vince
Vza is offline   Reply With Quote
