Old 03-02-2020, 04:47 AM   #33
SCCA_AX
Originally Posted by lawren View Post
I have my first autocross (SCCA STR Class) in a few weeks. I was wondering if someone could give me some tire pressure recommendations for:
1998 Boxster Base Model (2.5L)
Stock 17"x 7" fronts and 17"x 8.5" rear wheels
Bridgestone RE71Rs (225/45-17 front & 255/40-17 rear)
Front LCA (this is my only suspension mod at this point)
I wouldn't sweat it too much, the RE-71R is pretty pressure agnostic. Start at 35-37 square. Too much pressure (40+) and they get a little too sharp / antsy. Too little pressure and they just burn off the shoulders quicker, but aren't really any faster or slower.
If you go further down the STR rabbit hole and start running lots of camber you can probably start dropping down to the low 30s, especially in the front, and see time gains. Gotta test though.
FYI, if the tires are brand new, they tend to take an event or two to really hit full grip. Street miles don't speed up this process. Then they're pretty consistent until the tread is almost gone, as long as you don't cook 'em at a track day.
Good luck.
SCCA_AX is offline   Reply With Quote
