Old 03-02-2020, 02:30 AM   #13
driver8
Originally Posted by Burg Boxster View Post
PCA says IF you have roll bar, you MUST have harnesses.
The PCA DE minimum standards do not require this. From the DE minimum standards:
The participant should BE AWARE that the addition of such a seat and harness system results in the occupant being fastened upright in the vehicle. Therefore, in order to have a COMPLETE SYSTEM, a properly padded roll bar or roll cage is recommended, and an approved head and neck restraint device is required.
Granted a region may choose be more strict than the minimum standards, so it may be wise to check with the PCA regions you are planning to drive with.
driver8 is offline   Reply With Quote
