Old 03-01-2020, 08:10 AM   #11
MaxD
Originally Posted by jmitro View Post
Brey-Krause makes an adapter that allows the sub belts to be wrapped under the seat so you don't have to drill through the body, if that bothers you
https://www.bkauto.com/R_9044_Seat_Floor_Mount_Adapter_p/r-9044.htm
Sub mounts like that are great for those with street cars wanting to run multi point belts.
If you are actually racing PCA Club Race rules state: "Harnesses cannot be mounted to the seat or seat rail. Mounting must be to the chassis backed by large diameter washers (if stock mounts are not used) or to the roll bar."
NASA doesn't seem to have that particular requirement on harness mounting, but they do reiterate: "Large diameter mounting washers should be used to spread the load. Bolting through floor panels etc. is not acceptable without required washers."
PCA Intermountain Region Track Chair
SPB #50
MaxD is offline   Reply With Quote
