Old 10-16-2006, 06:56 PM   #10
MNBoxster
Originally Posted by Adam
Aww, yes that looks like the one. Any suggestions on who has the best price? Suncoast? Thanks for the help everyone.
Hi,
There is an issue with that European Motive Bleeder. That is, it doesn't have a swivel and to put the cap on/off the reservoir, you need to rotate the entire bleeder to avoid kinking the hose.
But, you can keep the Bleeder you have and just add this swivel cap - http://www.zimsautotechnik.com/acatalog/Metal_Swivel_Cap_for_Motive_Products_Power_Bleeder .html to the existing hose. It's billet aluminum and a very nice and durable piece, I have one and it's great. Hope this helps...
Happy Motoring!... Jim'99
PS The Brakes and Clutch share a common fluid reservoir, because of the ABS, you should not use the push pedal method to bleed the brakes. The ABS requires a constant minimum 18PSI to bleed properly.
