I have PSS9 coilover with camber plates and stock arms in front. About -2.8 deg camber front -2.5 rear. I set my height to what I had when I was running with stock struts and my HnR lowering Springs. I haven't measured using this method only using ground to fender arch. But running 17in wheels on the track my car looks very similar to THSTONE. I have 4-5 mm rake front to back.
So Maytag your numbers seem good. But I suspect I am sitting lower than your numbers.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
