					Originally Posted by aparke4  Hi all-
 I am going to give this tuner a go as its a code reader, remap/ programmer as well as has other cool features. I am keeping my 2002 Boxster S mild in terms of mods so I am hoping this will enhance the exhaust, intake and cayman TB.
 Thoughts?
 Here is a quick response I got from the seller via eBay:
 New message from: voloperformance Top Rated Seller(6,579Green Star)
 Thank you for your interest in the Volo Chip. The chip works by replacing the ECU's calculated fuel delivery and timing values stored in the temporary memory of the ECU at up to 256 load points. You can expect around 21 HP and 24 Torque on the Boxster. We believe you will like the VP16. Give it a try, if you have any more questions let us know. Thanks.
 Reply
 Your previous message
 Hi-
 Is this essentially a remap? I am looking to install this on a 2002 boxster s. Any specs for this vehicles with hp and tq? I have exhaust and an intake so it’s more of mild build/ naturally aspirated car.
 Model: volo 16
 Thx!
 The object of the game is to get more air into the engine!  The DME can easily supply the fuel required for the air metered by the MAF senser as long as the fuel pump & injectors are working as they should . Don't waste your budget on non essential toys.
				__________________OE engine rebuilt,3.6 litre LN Engineering billet sleeves,triple row IMSB,LN rods.  Deep sump oil pan with DT40 oil.
