Old 10-16-2006, 03:54 PM   #1
MNBoxster
Originally Posted by pecivil
so Jim, according to that line of thinking, the reason they put even LARGER brakes on the 911 S and the 911 turbo, is because they are heavier, and it has nothing to do with horsepower? I can't imagine that the Boxster S weighs too much over the standard model. Certainly not enough to justify larger brakes.
But, Hey maybe you are right, and Porsche only puts on bigger brakes to charge more $$$ and for the "bling" factor.
But somehow, I doubt it.
Hi,
Yes, Horsepower has absolutely nothing to do with how a car stops. You can have 1000 Horsepower on a Boxster and assuming the weight hasn't changed, it will still stop in the same distance with the same brakes as a stock 200HP one. If you're braking from 60 MPH you're braking from 60 MPH, it's the same whether you reached that 60 MPH in 3 seconds or 10 seconds, you are still braking from 60MPH...
Happy Motoring!... Jim'99
