Old 02-21-2020, 11:31 AM   #1
rastta
rastta's Avatar
Selling the Boxster S $35k OBO
Can't edit the title - I'm getting ready to pull the motor so last chance to buy as is. I'll take $25k. The Motons and Motec system are worth more than half that. If I don't sell as is - I'll fix it and most likely keep it.
Description:
I purchased this car six years ago this month and have really enjoyed it. However, in November of last year during a track day, the engine stalled momentarily on track and I limped it in to the pits. It was smoking considerably at the time. Upon bringing it home, I determined that the AOS had failed as there was lots of oil in the intake and runners. I took it all apart, cleaned it all up and installed a new AOS. After doing this - I ran a compression test which showed 235+ on all cylinders except cylinder 4, which was 100. So I put a new set of plugs in it and it fired right up. Last week I brought it in to Griffin Motorwerke to redo the compression test warm and do a leak down test. The results were similar with 190+ on all cylinders except cylinder 4, which was 90. Leak down confirmed it was the piston rings not the valves. Car has not been run other than loading and unloading it for the tests and to bring it home. It starts right up with minimal smoke.
2000 Porsche Boxster S Race car - 2,538# total weight w/o driver
Engine
· 2005 3.6L 996 M96-03 motor purchased from Suncoast
· Rear Main Seal (RMS) replaced Jan 2013
· Motor confirmed to have the Newer Intermediate Shaft (IMS) Bearing and modified seal
· MoTeC Engine Management - M820 ECU with Logging, dual lambda, active cam, e-gas and full custom harness
· Custom Dyno Tune by RaceTune in June 2018 on 91 octane. Dyno Sheet available
· New Porsche Motorsports Air Oil Separator in Decemeber 2019
· X51 Oil Baffle System
· Custom sealed double feed air box with K&N filter
· New coolant temp and crank position sensors in Dec 2017
· New coilpacks in Dec 2017 and plugs in 2020
· Remanufactured Bosch starter installed in Dec 2017
· FVD Exhaust headers Borla Race Mufflers with 3"exhaust (approx. 97 dB)
· 3" Supertrapp tips and 3" muffled Laguna turn downs
· MoTeC GPS Antenna for start finish laps and Google Earth race line overlays
Transmission
· AASCO Motorsports flywheel (machined and rebalanced in 2017)
· Used 6 Speed Transmission with 42k miles installed by IPB Autosport In January 2019
· Guards Transmission (GT) LSD GT2RPro 4340 Chromoly LSD 80/50 Lockup
· B&M short shifter with stock knob
· TuneRS Transmission Oil Cooler and pump kit with -10 AN lines.
Suspension
· OEM GT3 27mm - 5 way adjustable front bar with Tarett Engineering extended front drop links. Heim Joints replaced July 2018
· 19.75mm - 2 way adjustable Tarett Engineering rear bar with Tarett drop links. Heim Joints replaced July 2018
· Moton 15 position Double Adjustable Motorsport Remote Reservoir Shocks - Rebuilt by Performance Shock in July 2018. Shock dyno available.
· Mode Front Camber Plates - serviced with new spherical bearing in July 2018
· Front Wheel bearings replaced with FAG bearings in July 2018
· Sway bar bushings replaced front and rear in 2016
· Inner tie rods and boots replaced in June 2016
· FVD Motorsport aluminum front strut tower brace
· New Eibach Main Springs 700 pounds front, 800 pounds rear installed in July 2018
· Rennline Rear Subframe Stabilizer With Tie Downs (Front also has custom tie downs)
· Elephant Racing front Lower Control Arms installed July 2018
· Elephant Racing rear toe links installed July 2018
· Rear lower control arms, rear forward arms, front A arms, rear toe arms replaced Aug 2012
· All new OEM or hardened bolts were used during suspension refresh in July 2018
Wheels
· 2 full sets of Enkei Performance NT03+M (One set new in November 2018), with 1 rear and 2 front spares. Both full sets are shod with NTO1's which have several days left on them. 245/40 and 275/40 f/r. Spares have slicks on them.
· Front - 18x8.5 and Rear - 18x10
· Race studs front and rear
Brakes
· Stock calipers and rotors (Front calipers rebuilt in 2016 with new seals/boots. New seals and boots for rear calipers to be installed)
· Pagid Yellow RSL1 front pads and Black RS19 rear - one day on new pads
· Motul 660 fluid
· Goodrich Braided steel brake lines
· Custom brake duct intakes with direct feed from front with hoses and custom fittings on wheel hub
· ABS switch on dash to turn ABS on or off
Interior
· Kirkey Ultra Shield race seat
· Driver seat rear seat brace
· New Schroth 6 point Hans compatible race harness - (Expiration Date)
· Schroth window net
· Schroth right side driver net
· Momo alcantara wheel with quick release hub and radio button
· Custom carbon fiber dash inserts
· 3" dual custom driver air ducting from front cowel
· MoTeC SDL Dash logger with data port and MoTeC i2 Standard Data Acquisition
· Longacre drink holder and bottle
· Video camera mount
· Cool Shirt System with custom made cooler and in dash pump switch
· Motorola Communication system with radio holder, antenna and wiring. Complete pit radio system included.
· Rennline perforated pedals and dead pedal
General
· Full CroMo 1.75" welded in cage with padding for driver
· AMB Transponder
· 3 Jet Fire Bottle FE-36 Fire Suppression system with full tank
· Lexan windscreen with Tearoff cover and vinyl screen.
· Custom Lexan rear window
· James Lister & Sons 52mm Air jacks (3) with spares
· Cup Car Solutions SpeedWand trigger airjack air control wand
· New Odyssey battery in 2017
· All new 0 ga positive and negative battery cables for entire car with new copper ends and new OEM alternator/starter cable in 2016.
· GT3 Cup fiberglass front nose with center radiator with custom radiator and brake ducting
· Fiberglass front hood
· Custom engine cover with dual integral fans (switch on dash)
· Custom side scoops that provide air to the intake and oil cooler/starter
· Front side radiator fans can be turned on and off with a switch on dash
· Ultra light fiberglass roof (no liner) and factory attachment points
· Fiberglass front light replacement covers (no lights but wiring intact)
· Single custom windshield wiper
RACE CLASS
PCA Class GT3S
POC Class R3
NASA Class GT3S
rastta is offline   Reply With Quote
