Old 02-20-2020, 11:14 AM   #13
Starter986
1998 Boxster Silver/Red
Originally Posted by mikefocke View Post
There is a list of parasitic drains here. Page down about two pages and lots of detail on draw versus time and even the draw from individual items.
Also check the battery terminal to cable connections are clean and tight.
My first approach is voltage at 3k RPM. Voltage after 1 hour from shut off. Voltage after 24 hours. Don't be afraid to load test the battery.
Good advice.
My Bosch battery is 2.5 years old. Twice in one month... ~5-6 days between starts... battery was dead. Took it to AZ... load tested it: Good battery.
I had repaired some wires connected to the + cable... and tightened everything up... after the first failure. The second time, after recharging the battery... took it back to AZ: Good, again. Bought the $3 post cleaner. Cleaned everything up.
2 weeks later my voltage LED is reading ~14V.
All back to normal.
1998 Porsche Boxster
