Originally Posted by Nine8Six
Nice one, Paul. Those heat-wraps should be plenty sufficient to secure that old wiring. Yours must have been a DD often driven during evening/night, seen that weaken wiring before where others driven less during dark hours are still fine today. 55w halogen = 5amps (4.5?) constant on that tinny wire
If I'm right i.e. the new ballasts let pass an incredible amount of init current (depending on the new circuit resistance) then that lil puff of smoke you've seen is no surprise. One way around that is to beef up the gauge size within the headlight assembly or ideally connect the ballast power rail to the battery directly. The latest being what many retrofiters does in fact and the safest set-up (requires extra wiring and some clever fiddling).
Are those new ballasts engineered for high power 55w or 35w? you know? In any case you'd want the small/cheap 35w preferably. No need to go overkill there...
Thanks again Fred. I have 35w ballasts. And I'm doing this project with a bunch of well-used headlights I picked up relatively cheap. My headlights are in great shape and they are still in my car with your GT Collection projectors as built by Particlewave. Last year one of my inner lenses in those projectors came unglued. Earlier my COB Halos in those lights had died, even though they were on relays and only lit up in the parking light position, turned off in the headlight on position and I never used them. I was able to re-wire and re-install my parking lights in those headlights, so rather than bother Charles and go through shipping my light again, I disassembled the light and re-glued in the inner projector lens with help from Charles. This all happened about a week before a 1,000 mile road trip in the car for a track event. Which is why I bought these used headlights, I used one in its original shape for that road trip. Having had a success in removing the outer lens and reassembling that light, I thought it was time I tried to build a spare set for myself.
Here is a picture of my car at Virginia International Raceway with one good looking GT Collection bi-xenon headlight and one very tired original amber headlight with a very burned inner lens!
