Originally Posted by Homeoboxter
Hey Folks, I`m a bit confused with this chart on torque settings. There are two different angle values (90 vs 110) listed for the conrod bolts, but I can`t see the difference, the text is the same for both.. Could someone enlighten me please? See below.
It's a 2 step process, 1st torque to the 1st spec for both bolts on the same rod, then tighten the stated degree. So if it calls for 90 degree, tighten a additional 1/4 rotation. I'm not sure about the 7r designations because I always chunk the stock bolts & install ARP bolts that have a torque spec only, and they are much better than oe.
I have a set of ARP's in stock I'll sell if you want to upgrade.
