engine size on the swap
based on what I found out, it isn't the physical size of the engines, its the electronics that control them.
If you have a pre 00 boxster you do not have Egas. So the easy swap (easy meaning that the ECU and wiring stuff all is pretty much P&P) is a 3.4 carrera engine that did not have egas.
If you have a 00 or 01 boxster (I am not sure about 03) then you want a 00 or 01 carrera 3.4. This engine has egas, and has variocam, exactly like the boxster 2.7 does.
If you have a 00 Boxster S, then you go with a carrera 3.6. This engine has variocamPlus, which the boxster S has. Plus it has the 6 speed tranny, that is the same as the 996.
If you have a 03 or later boxster, I think you go with the 3.6 carrera engine.
If you have a 03 or later BoxS, then I think you can do the 3.8. Not positive on this.
If you have a 987, then you definitely go with the 3.8.
So its not that you can't do the 3.6 or 3.8 in the earlier boxsters, but you need lots!! of electronic wizardry to make the electronics work right. I think it has been done, but it makes the swap much more difficult, time consuming.
I would have loved to done a 3.6, but my 2.7 doesnt have variocamplus, only variocam, so I needed a 3.4 to be plug & play with my stock harness & ecu.
Make sense?
Arctic Silver 2000 Boxster 3.4l w/Sport Design Package
Supersprint Boxster S Headers/Cats/Muffler
AASCO Lt. Wt FLywheel
Evo Intake
Partial Carbon Interior
Black Leather Sport seats
M030 Sway Bars
Litronics w/ Clear Corners
Boxster S brakes
B&M Short Shifter
PnP rear Speakers + Amp
