Old 02-19-2020, 02:14 PM   #12
Gilles
Originally Posted by RobT987 View Post
I'm not sure it can be done as the quickjack uses the same jack points as what the jack stands would use. If there is a different set of jack points that doesn't interfere with the quickjack then it sounds feasible.
If you're concerned about the quickjack being safe to use with the extensions, I've had my Boxster up on the quickjack for over 2 months and it's been rock solid.
RobT
Sent from my Pixel 3 using Tapatalk
Rob, actually my concern was not the use of jack points but more the way the quickjack raises and lowers the vehicle.
As I believe the quickjack raises and lowers the car in an 'arch movement' (not straight up and down) this means that when you want to lower the car it would slightly move forward, I am not sure if my explanation makes any sense.. :-(
