Old 02-19-2020, 11:18 AM   #11
RobT987
I'm not sure it can be done as the quickjack uses the same jack points as what the jack stands would use. If there is a different set of jack points that doesn't interfere with the quickjack then it sounds feasible.
If you're concerned about the quickjack being safe to use with the extensions, I've had my Boxster up on the quickjack for over 2 months and it's been rock solid.
RobT
Sent from my Pixel 3 using Tapatalk
RobT987 is offline   Reply With Quote
