Old 02-17-2020, 05:49 PM   #10
TRP
I'm back with another quick update.
I managed to score a pretty good deal on a 987 Bose rear sub. It's slightly different from the 986 version. The ports are more pronounced. Technically only one is a port. The other side is just cosmetic.
I opened it up and found that the 987 version also had a small amp / combination crossover. I ditched that and rewired the 5.25" drivers to be 2 ohms. The little speakers in the corners are wired to deck power @ 55W each. They aren't too loud but they do provide a nice rear fill.
I added a mono amp and picked up signal right off of the DSP. I was able to adjust the 6" door speakers to handle all of the mid-bass. The rear box picks up all of the lower frequencies. I still have a big gap around 100hz. Rock music is just missing something. I may go back into the doors and seal up those vented boxes to try and get more from them.
The blue coiled USB cable is for the DSP. I can quickly hook up the laptop and dial the sound in. Once I get the ACR-3 source changer for to quickly select / swap between settings I won't need to leave that hooked up. I may go back in and pull some thin black abs panels to hide the wires below the amps.
If I'm being 100% honest, the Bose box is okay. I kind of wish I had both the Bose box and the previous speaker box with the 4 3" drivers. I will be putting that box (complete with Haes speakers) up for sale soon.
Thanks for letting me share!
TRP is offline   Reply With Quote
