Steve, House, TRK, NewArt, AZ986, and any others who are frequent trackers:
So I assume RoW sport is M030 spec?
That's like 40mm from 90mm minimum (spb allowed).
I want low.... 'cuz it looks cool.... but not so low i start giving up performance at the track.
I'll be running 18's on the street, 17's at the track. MOST of its time is spent at the track, and I tend to orient my mods in that direction.
What're your recommendations?
'03 S, gt3 bars front and rear, adjustable LCA's, camber plates, ohlins R&T coilovers (track package, so a little stiffer spring and valving) , running NT01'S, with lots of neg camber.
Edit: I should also note that I'm running the LN deep sump, with sump guard plate. It IS the lowest thing under the car now..... which concerns me just a bit. Especially as much as I like using the curbs.
Edit again: I'm currently at 113mm in ther front and 138 in the rear. The rear actually seems about right, but could maybe come down 10mm. But before I do anything to the rear; the front is too low. The tops of the tires are hiding in the arches, and I can't get a jack under the nose. I think I'll probably bring it up about 17mm, to 130mm.
