I'm nearing the end of the list I've been working-on for the last several weeks while the weather's been cold.
Transmission
Drain and Fill Trans Fluid
Install detent
New Shift Cables
Adjust shifter
Sump Guard
Exhaust
Wrap Headers
Install Headers
Install Mid-Pipes
Install o2 sensors
Lengthen sensor wiring
Cut-Open and Weld the Muffler, or replace
All New Stainless Hardware
Engine
Change the Oil
Install the Oil Filter spin-on Adapter
Install the Replacement Coolant Hose, REFILL
Insulate the Power Steering line (near the CAT)
Suspension
CoilOvers
Camber Plates
Thrust Arms (adjustable)
Toe-Links (Rear, adjustable)
Sway Bars and Adj End Links
Set Ride Height
String-Alignment
Brakes
Paint the Rotor Hats
Clean & Paint the Calipers
Apply stickers
Clear paint
Pads - (Put back in the Raybestos)
Change-out the brake fluid
Change Wheels & Center Caps
Get the Race Tires swapped onto the other wheels
Wheel Studs
Engine
Swap MAF
Clean the TB
Air Filter
confirm operation of the resonance tube valve (see the attachment in the email)
Install the Tune, OR-GET A NEW TUNE
Install the SideSkirts
Complete the Wrap
Swap the Resistors for the radiator fans
Door Cards
ReFasten the Cards
Replace the speaker, R-side door
Fix the Heater / A/C Door
Waterproof the Immobilizer
Purge Fan Switch
switch to run BOTH radiator fans on High
Die the Seats
Auto-Top Relay Mod
Swap the Microswitches to fix the Window-Drop issue
