Old 02-17-2020, 07:00 AM   #11
AaronF
INFOSEC Ninja
AaronF's Avatar
Originally Posted by specboxCO View Post
eliminates the need for the Vehicle Speed Sensor (super important to making the 40v engines work)
How did you remove the VSS requirement?
I'm using the no-VSS bin from your post in this thread (#189) on my S8 swap but my engine has S8 specific cams and a 1 stage intake manifold. I have a S8 bin for my AYS engine but can't figure out how you removed the need for VSS. I've compared the bin for both engines in TunerPro but can't seem to pinpoint your change.
EDIT: I think I may have found it. I modified the bin file at address 16778 from hex 7454 (5405 RPM) to 8070 (7200 RPM). I believe this is NMAXDV, "maximum engine speed on speed signal error detection". I just took the car out for another test and it revs all the way up to 7200.
'03 Boxster with an Audi S8 4.2L V8 - https://sites.google.com/view/boxsterv8swap/home
'06 Cayman S Tip
AaronF is offline   Reply With Quote
