Originally Posted by maytag
Start with the exhaust. Get it to breathe better there, then maybe a hi flow air filter can help. Then increase the size of the TB, and you will want to increase the size of the intake feeding it. But just throwing on an intake that can feed more air than the motor can use isn't going to help it.
And then there's the risk of introducing hot air while you're at it.
I 100% agree, that an intake by itself, wont give you much.
Exhaust, plenum, throttle body, etc.. are necessary to actually benefit.
And we are agreed as well that heat management is key. Its obvious by the placement and closed nature of our engine bay that, its not enough to just throw in a filter with more direct intake route.
There just seems to be this contention that there is no way to make more power than stock box, which I just cant believe from experience.
