6'3" & 249.999lbs OK......................
I'm 6'3", and 250lbs with little problems once inside the car. In and out can be a little challenging due to the length of my legs. I have found that when exiting, if I place my left hand on the door jamb, I can leverage myself out without too much effort or public gawking. Occasionally, once standing next to the Box, I'll get a bystander that appears to be amazed that I fit inside (heightwise).
The only caution I have is the panel that houses the contols to the seat can be caught if you try to slide over the seat on the way in/out. So be sure to lift your arse upon entry/exit.
Otherwise, driving is no problem! Pedels are easy to manipulate and my knees are out of the way, not up against the steering wheel. The only other coupe that I've been in that had more leg room was a '69 XKE.
Mark
Seal Grey 01
